suspension noise
Old 01-17-2013, 09:06 PM
2001 White XJ8's Avatar
Originally Posted by jag_genius
check or replace the front sway bar bushings.. not the links.. they give you a hollow sound in the floor.. there like 12.00 each at the dealer.. and take 2min to replace.. 4 10 mm bolts
I have the exact same sound coming from the front end of my car. It has been doing it for a couple years. I looked up under it today with the knowledge gained in this thread and I think this is the problem with mine.
While pushing up and down on the car at the fender and looking underneath I can see slight play in the sway bar bushings and at the same time hear a corresponding sound. I will replace them and report back.
Old 01-18-2013, 06:46 PM
D. Fite's Avatar
Originally Posted by JagtechOhio
How about some feedback on the ride and handling difference with the KYB's?
I installed the KYB's on the rear. Some of the members here feel they are a little too firm but I like them. I installed Monroes on the front and like the feel of them also. Takes some time and PATIENCE on the rear. The main thing I would stress is to get the shock bolts good and tight and be sure to locktite the nuts. I really feel that the main problem on my rear shocks was that the upper nuts backed off slightly causing a thumping sound. The old shocks I removed seemed to be in good condition.
Dave
Old 01-19-2013, 09:48 AM
ant17's Avatar
I never did find the cause of the thumping sound, like loose lumber in the trunk. Shocks are still good. Changed those bushings on top of the shocks.
Old 01-20-2013, 09:22 PM
Suspension noise gone in my car. Jag Genious was right on the money. But, my local Jag dealership didn't have the sway bar bushings and they wanted $18 each for them. I removed my old ones and cleaned the bushing really well with silicone grease. I then applied several coats of paint to the brackets. The paint makes the bushings fit tighter. I then used white lithium grease on the inside of the bushings when I installed them. The noise is completely gone.
Old 01-20-2013, 10:03 PM
Alvin Burns's Avatar
Chasman, now that you solved your problem, would you please tell this old fossil what on earth "&bsp\\;" is? Can't find it in any dictionary I own.
XJ8JR
26
08-08-2020 09:38 PM
JimC64
31
05-30-2016 03:04 PM
driver safz
09-26-2015 06:01 AM
redgear
09-18-2015 10:05 AM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
Quick Reply: suspension noise
