Swapped transmission now car won't start
Hello I have a 98 xj8 vanden plas I recently swapped out the transmission due to a failed A-drum now my car won't start I've made sure to reconnect everything including the ground wire it tries to kick over but no start if I can get some help it would be highly appreciated thank you
Welcome to the forum Danile357,
I've moved your question from General Tech Help forum to X308 forum. Members here with the same model will be able to help you troubleshoot this issue.
When you get a minute, please follow this link https://www.jaguarforums.com/forum/n...-intro-must-5/ to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Good luck with the fix.
Well, if that is the case, forget codes, cylinder wash (its a condition, not a process), crank sensors and virtually everything else in this thread. I guess everyone assumed it would be obvious that if your starter is not turning th eengine, then either the starter "Bendix" gear is broken or you have something assembled wrong and the starter cannot engage the ring gear.
Frankly, I would expect that a person who could successfully R/R a transmission would be able to tell why the starter cannot turn the crank. After all, you are there looking it at it and we are not. I say this not to bust your chops, but rather because I suspect one side or the other of this conversation is "failing to communicate"!
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
SingBlueSilver
08-27-2015 02:20 PM
