Sway bar bushing replacement
I am going to replace my front sway bar bushings this weekend (...um...going to try....), but wanted to find out form you all if it is better to do this job with the suspension still compressed (car on ramp), or with suspension extended (car on jack stands)? Anyone have experience with this? Thank you.
I used jack stands also. I think you could do it without lifting the car but it is easier to reach the bolts if you do.
I did have some trouble lining one of the bolts on the drive side. I used another hydraulic jack to lift the sway bar slightly and the holes finally lined up so I could re-install the bolt.
Minus that little problem the job would have taken about 15 minutes - most of that time was spent lifting the car and removing/replacing the plastic cowling under the bumper.
You may want to have some liquid wrench on hand in case the bolts are rusted.
It is an easy job and it made a world of difference on my car. No more clicks/clacks and the car handles better.
Joe
98 VDP
Joe
98 VDP
I just did this with the car on the ground. No jacking required. Some of my splash guards are missing though. Completely got rid of the super loud clunking sound coming from the front end. I thought for sure it was the shock mounts or something serious! Best 20$ I've spent on this car.
No problem, here is where I got them from. Make sure you know if you have the comfort suspension or the sport.
https://www.trademotion.com/partloca...layCatalogid=0
In case you are wondering (as I was), removing the link arms from the sway bar ("stabilizer bar" as it is called in the workshop manual) is not necessary to replace the sway bar bushings. It is not clear to me why the manual would have you remove the entire sway bar from the vehicle to swap out the bushings. After you remove the bolts securing the mounting brackets, the brackets and old bushings easily come off, the sway bar stays almost perfectly in place and the new bushings (lubricated as instructed (non-petroleum)) slip right on. I did this with both sides of the front end on jack stands and I did one bushing at a time (rather than removing both bushings before replacing either). Apologies if this was obvious to everyone but me.
Also, since it is relevant to this thread, the part number for the sport suspension bushings is MNC2102CG. I was unable to find these except at the local Jaguar dealer for $12.00 each.
KarimPA
09-03-2015 07:32 PM
