tapping noise after tensioner change
Just wanted to know possibly what this could be. Engine at cold start will do the same tapping noise. I changed both secondary tensioners which were worn out and original yesterday and until the car is warmed up it will tap. I can accelerate to 1500 rpm and it will make a whirr noise and go away. I have read where a VVT can cause this like its sticking. The car was sitting for almost 2 years with bad fuel pump. I am not worried about the engine because the chains had NO slack at all in them and new tensioners, oil changed and all runs good. just wanted to know anyones opinions.
innzane
09-02-2015 10:08 AM
