TB & supercharger gasket source?
I'm setting up to pull the supercharger on my 99 XJR. Mostly to insure I can change the oil out in the blower and to swap out the coolant lines that may (or may not) have become brittle over time. I'm having trouble finding a source that actually shows the gaskets I'll need to come up with for this task. I'm assuming I'll need the supercharger to intake gasket and several seals for the intercoolers to blower but am not sure how many more connections I'll be disturbing. If you've done this job and can point me at the supplier you used that would be appreciated.
Also when I drain the coolant is there a source you'd recommend for appropriate Jaguar friendly coolant? When I drained the coolant on my e39 beemer beemer coolant was recommended as there were specific needs associated with their choice of cooling system materials.
Thanks!
Thanks!
Received 2,193 Likes
jahummer
07-29-2019 10:13 AM
Harry Peter Rose
02-12-2018 08:04 AM
Cambo
02-05-2018 05:45 PM
Lagonia
03-03-2016 09:18 AM
