Tech help - shuts down on startup
Attempting to bring my wife's '99 XJR out of winter hibernation. The car fires right up, settles to normal idle and shuts down immediately. The fuel pumps have been replaced, and the symptoms are different than a failed pump. It's not a slow run down for lack of fuel pressure but rather feels like the ignition is being switched off. The check engine telltale is on. This car is also my template for assembling an XJR transplant into a Mark 2, so it's possible I disconnected something and failed to reconnect it over the winter, but for the life of me I can't think what that could be. Any thoughts much appreciated.
Please include these sorts of details in the first place. They show you're now looking for a fault in the car's OBD system. Use the workshop manual for help on fuse(s), wiring etc.
Mine has done this a couple of times, and on further investigation, I found that the ignition key was actually popping back to the accessory position and turning the engine off. I think it happens when the ignition lock gets worn.
When it has stopped, check the position of the ignition key.
JagV8 (04-13-2017)
