tensioner bolt help
Old 05-10-2011, 09:17 AM
Ryanday's Avatar
Default tensioner bolt help
I orderd ford part number W705391S300BOLT - M6 X 1.06 X 40 HEX
I got that number off of a post here for the bolts to hold my new upper tensinors but it seems these bolts are to long they feel like they have bottemd out in the hole. They look just like the other bolts just a bit longer plz help
Old 05-10-2011, 11:26 AM
Ryanday's Avatar
ok so that was the worng part number that someone gave to me on another thread. I got some shorter bolts and everything is working great. I already have one side done and put back together. It was split really bad still holding good.
Old 05-10-2011, 02:36 PM
JimmyL's Avatar
I thought they were supposed to be shorter, but it's been a while since I did the job. Be careful on the other side. When I pulled one of my old tensioners out it fell apart. I was lucky I didn't drop anything down inside the front cover because I was not expecting that. Best of luck !
Old 05-10-2011, 05:16 PM
Ryanday's Avatar
All done she is running like a top!
Old 05-10-2011, 07:17 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Please identify the post that had the incorrect bolt information so that others do not follow the same path.
Old 05-11-2011, 03:08 AM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
Come to think of it, that may be the reason for the recent spate of "ticking after tensioner change" threads.
There are a lot of people wandering around who would happily torque down a bottoming bolt and call it good without questioning why or noticing that the bolt has bottomed.
Well, the resulting gap is not going to allow the tensioner to build up pressure to design levels. And will certainly allow the tensioner to leakdown when shutdown. It will also starve the VVT that is in the neighbourhood if it is a NA application.
The reason that the ticking disappears with increased RPM is of course that the oil volume increases with RPM. At some point the volume of oil is able to mask the leak. The same is true with regard to the use of thicker oil - it too will help to mask the leak.
It is hard to detect after the fact for the inexperienced because the piston spring applies some pressure and holds the tensioner steady and their fingers don't know the tactile difference.
Old 05-12-2011, 12:30 AM
Ryanday's Avatar
Was in the thread i posted with the title new owner help.
Old 02-16-2015, 07:18 PM
jonpalley's Avatar
What is the length of the shorter bolts? I have this same problem.
Old 02-16-2015, 07:29 PM
test point's Avatar
They are only about an 1/8" shorter than the original but that makes a big difference.
If you have the longer bolts go to the local ACE and buy 2 nuts that fit the bolts. Put the bolts on and grind/Dremel/cut the 1/8" excess off and then take the nuts off to clean up the threads.
Old 02-16-2015, 07:37 PM
retromotors's Avatar
Originally Posted by plums
Come to think of it, that may be the reason for the recent spate of "ticking after tensioner change" threads. ......
Good point!
In addition, I think I remember reading that using the long bolts with the later tensioners blocked some sort of oil passageway ...???
(Wouldn't swear to it, though.)
Old 02-16-2015, 07:39 PM
Jhartz's Avatar
Or -- go to Christophers or your local Lincoln dealer and buy the right bolts.
Old 02-16-2015, 07:51 PM
I checked that thread, didn't see any mention of the bolt part numbers you listed above.
Must have come from somewhere else.
Oh well, good deal that you caught the discrepancy!
Old 02-16-2015, 08:09 PM
test point's Avatar
Fix it!
Old 02-16-2015, 09:02 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
That brings up the notion that one should check archives for additional information on many matters. There is certainly no shortage of bad information on the internet, and yes, even on this forum. Some posted by me, I am sure!
Old 02-16-2015, 10:02 PM
Received 8,131 Likes on 4,906 Posts
For reference, the front timing cover bolts are the correct length for the metal bodied secondary tensioners. You could also add a short spacer or washers in a 'pinch'.
Just make sure the tensioners are TIGHT against the head.
I never have to buy the shorter bolts anymore because I just take them from the front timing cover of the several 'scrap' engines I have around.
bob gauff
Old 02-16-2015, 10:40 PM
plums's Avatar
Originally Posted by retromotors
Good point!
I think it would be more like the oil passage between the block and the tensioner
does not seal at the mating surfaces and then the oil is free to take the path
of least resistance rather than acting on the plunger.
In addition, the tensioner will have a case of the wobblies. (see JTIS for definition )
For future readers, AFAIK, the shorter bolts are 35 mm measured from under the bolt head.
Be sure to clean oil out of bolt holes to avoid hydrolocking even with the shorter bolts.
Notes copied from my cheat sheet:
Code:
secondary tensioner     : 10-14 NM  90lb/in
camshaft bearing caps   :  9-11 NM  90lb/in
sparkplugs              : 25-29 NM  WITH ANTISEIZE, new:1/2 turn max after finger tight, old 1/12 turn
                                    (NGK: 24.39-29.27NM / 18.0-21.6 lb/ft)  (DENSO: 20-30NM / 15-22 lb/ft)
                                    target value = 20 lb/ft
                                    220lb/in
                                    180lb/in = 20NM
valve cover             :  9-11 NM  90lb/in
Coil on Plug Bolts      :  4-6 NM   35lb/in
Coil Cover Bolts        :  4-6 NM   35lb/in
Note: The installation torque values shown above apply to new spark plugs with anti-seize
      according to JTIS.
NM to foot pound-force 0.737562147282
NM to inch pound-force 8.85074576738
Old 02-16-2015, 10:50 PM
plums's Avatar
Fix it!
Don't think the OP can do anything about it if it was in a response
written by someone else.
Mac Allan
07-20-2020 05:46 PM
04Xjrsteve
05-07-2019 04:06 PM
Dave1109971
12-15-2015 06:16 PM
Collector1
09-26-2015 05:28 PM
Quick Reply: tensioner bolt help
