Tensioner question
I'm going to be changing the upper tesinors on my 99 xj8l. I am needing some info on the zip tie method. I can't seem to find any. Thank u. Also the car has a bit of a stumble when u first push the gas then it smooths right out. At an idel in park if I just push the gas pedel really easy it almost dies. But it I push it on down it revs on up like nothing is wrong.
The reason you cannot 'search' on 'zip tie' is that the forum software will not search on less than 4 characters in a word.
Here is the link to the original posting on the zip tie procedure but there are others with pictures that I cannot find at the moment.
https://www.jaguarforums.com/forum/x...15/#post208259
JimC64 (01-31-2012)
Hi
I copied these 3 links for you:
This one shows you the ziptie that has been placed on the timing chain.
https://www.jaguarforums.com/forum/a...cs-zip-tie-jpg
Next one is a PDF with instructions and pictures on how to take the cam (valve) covers off to inspect the secondary timing chain tensioners.
https://www.jaguarforums.com/forum/a...4&d=1299472295
The last is a webpage link to the thread on how to do the ziptie method.
https://www.jaguarforums.com/forum/j...15/#post317113
Look at the early posts #1 thur #8.
Hope this helps you.
Jim Lombardi
Jim Lombardi
JimC64 (01-31-2012)
Hey I'm back Im still loving my jag!! but my grandfather gave me a 00 lincoln ls with a 3.9 v8 i know the motor is really close to the same as my 4.0 in my jag. Any one know it the timing chain tensonies are the same? It really needs them changed but I'm finding limited info on the web. I know this is the jag forum but I know u guys are great on these motors and questions thank u
Received 6,312 Likes
test point (01-16-2012)
Lincoln LS - Lincoln vs Cadillac
I've owned an LS for 8 years and love it. Someone hit it while parked and that's why I'm looking at this site (possible replacement).
Engines in the t-bird and the VPJ should be very similar.
My LS is a V6. I've been driving 34 years and so far I've only owned cars with manual transmissions and RWD. One of the things I'm still on the fence about on XJ8s is the auto transmission. I do my own work and while I've changed clutches I usually get over 150K out of them so it no big deal. The MT's only need simple fluid changes and are not fussy as to what fluid is used. Going auto will be a big change for me.
In the type of car I'm seeking (4 door rwd) manual transmissions are few and far between (at least in the US), especially used ones.
So just a fast question the tensioner on the passenger side of my Lincoln the top was totally broke off that is were all the noise was coming from. The car was running but really ruff with no light on. Is it possible that it could have jumped one tooth on the timing and if so can I just move the cam back to where the flats line up when I get the new tensioners I ordered?
My suggestion....do a compression test by using a bar, socket and hand turn the engine over on the crankshaft pulley nut, to test each cylinder, it should pump in the region of 160-180psi for a happy smiley face.
If it checks out ok, it's a case of replace the tensioners and time it, then button back up.
ok so looks like bad news i put the new secondary tensioner in the passanger side and looked good turned motor over by hand and at one point and its where the cam flats are lined up there is enough slack in the chain to put my finger between it and the tensioner but if you turn it just a bit past it is tight agian is this ok or is the chain streached to bad and i need to get a new one and if so anybody had any luck with the chains that have master links?
Dickie_L_J_O
09-13-2015 07:44 AM
davidladewig
09-11-2015 06:48 PM
