Is there a way to change what rpm shifts happen at?
Run 722.6 adaptation procedure:
http://www.w203.pl/download.php?id=1...5ee68da06bc348
Actually the following is easy way to reset:
- Turn key to ignition (don't turn engine on)
- Press the pedal all the way down for 15 seconds
- Turn key to off (leave key in)
- Release pedal
- Wait for at least 2 minutes
- Release pedal
The following 2 users liked this post by XJR-99:
Dal2AR (05-02-2013),
WaterDragon (04-25-2013)
- Release pedal
- Release pedal
This link does not work.
What will the reset set it to?
How about this link:
http://www.europeantransmissions.com...6_adaption.pdf
When I made reset first time I noticed higher shift points also with WOT ( from ~5700 to 6000 ) and car was somehow more aggressive.
plums (04-25-2013),
Question, it is saying to accelerate, not exceeding 24oo rpm 4x 1-2 shift, then 4x 2-3 shift, then 3x 3-4, then 3x 4-5 ? Is this to be done by starting from a stop for the 1-2 shifts 4 times, then rolling 2-3,2-3,2-3,2-3, and so on? Then letting the car idle for 10 minutes.
Am I getting this correct?
And the rate of acceleration is not important, just not exceeding 2400 rpm, correct?
That link worked.
Tried it again, this time it took.
1st -> 2nd 4x kept below 1600 rpm
2nd ->3rd 4x kept below 1600 rpm
let car idle for 11 minutes
Now 1st -> 2nd shifting at just below 6000 rpm! definitely adding to the fun factor
This may sound strange but the car is getting to the point where I don't think it "needs" to be much faster....
but that NOS bottle in my garage whispers to me when I walk by
why would anybody want to dog a nice car. i have mine to take nice easy drives. when i want to get down i have a 1955 chevy 2 dr all steel body, street legal ( turn signals ,wipers,headlights, not stock exhaust) that i go to the strip and run. last time 186 mph 8.3 sec in quarter. 688 ci, 2 4's dual stage noz.
The point of my post was how to get my 1st to 2nd shifts back to 6000ish rpm.
What is your point?
Are you suggesting we should all install throttle stops at 50% throttle?
should our street cars should all shift at 3000 rpm?
When I want a calm idyllic ride I drive it that way, and it behaves like a docile kitten, but when I punch it, I want it to shift at 6000 rpm, not 5400, this is not making the car less elegant.
Explain your post
What is your point?
Explain your post
Last edited by WaterDragon; 04-27-2013 at 05:22 PM. Reason: pulled my head out of my ***
@ WaterDragon - cool ya jets dude I understood it as an agreement to your " I don't think it "needs" to be much faster" from his example is the 186/8.3 when he want's to really go fast? No?
Anyway, nice to see the advice on adaptation given and your results, I'd look into the bluetop solenoids as 99 suggested, you know they're an AMG/Maybach update with much higher flow rate, changes are tuned as you've just done, Andre' posted a great thread about dialing them in. Good fun
http://www.pjp.fi/osatorikuvat/420.jpg http://www.pjp.fi/osatorikuvat/416.jpg
British car can also be fast and luxury at the same time, like this local everyday one: http://www.pjp.fi/osatorikuvat/425.jpg
OkieTim
09-08-2015 04:48 PM
