Is there a way to install a XJ40 diff into X308 XJ8?
Old 07-23-2013, 03:51 PM
MoscowLeaper's Avatar
Default Is there a way to install a XJ40 diff into X308 XJ8?
Hi, guys.
I have an option to get a FREE 3.77 diff with LSD from XJ40. I'm feeling a lack of power and a LSD is a quite handy option during russian winters.
Is it possible to fit it to mine XJ8? What mods are required?
Old 07-24-2013, 10:11 AM
adam699's Avatar
Probably easier in an xj8 than an xjr computer wise. Search my threads. I have an old thread that walks you through the mechanicals. I have 3.58 with a loc on my car.
MoscowLeaper (07-25-2013)
Old 07-25-2013, 09:13 AM
Adam, what did you do with an offset of an older style diff? Did you just fitted a jurid coupling or driveshaft mods were required? Thanks.
Old 07-26-2013, 01:43 PM
adam699's Avatar
You need the diff and the matching frontplate. The front plate needs to be modified to have exhaust hangers. Other than that it's a bolt in. The offset is minimal and requires no modification. Just make sure to get the diff with the right coupling for the jurrid. Some of the older ones have a 4 bolt flange that will not work. Swapping the flange from the x308 differential doesn't always work because of the spline count on the pinion gear.
MoscowLeaper (07-26-2013)
Old 09-17-2015, 01:22 PM
the XJ40 diff is offset slightly and the 308 is centered if i remember correctly
dsnyder586
04-04-2019 02:38 PM
vsol
08-29-2018 09:46 PM
FrickenJag
09-25-2016 08:00 PM
AtholC
09-09-2015 09:07 PM
SteveSheldon
UK & Eire
09-08-2015 11:22 AM
Quick Reply: Is there a way to install a XJ40 diff into X308 XJ8?
