thermostat
holiday,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X308 forum. The Advice / Feedback & Suggestion Center is for posts about the forum and not for technical questions.
Members here with the same model will be able to help.
I disagree! The knock circuit is a high impedance input and even dampness can affect it. I suspect the OP has an AJ 27 engine, on which the knock detectors themselves crack and become very sensitive to moisture. Mine would RP on a damp day. All fixed by changing the sensors.
Many many times when folks have posted in the past about RP suddenly occurring, the answer was yes when asked if they had given the engine a bath.
BTW, holiday, it is wise to add your car's vitals to the signature since the various models can have very different characteristics!
holiday (07-25-2014)
heh, heh. The sensors on my AJ 26 engines have never given a problem, but each sensor in the AJ 27 (separately) started giving RP when any moisture, including rain, got near the engine. After removing them, I saw minor cracks in the plastic cases on each and the resistance measurement was much different than the specification from JTIS. I do not recall the connectors (which are actually on the thermostat riser), to look particularly vapor tight, so it seems like they could also be sensitive to even a little moisture which would track between connections.
BTW, I feel lucky that the bad KS were on the NA car!
I took my car to a mechanic to have the thermostat replaced and a week after my restricted performace light came on and i took it to another shop because the previous mechanic broke my manifold case and did not tell us. We noticed a few days later that there was a leak around the seal. We wanted to take it back to him but i was skeptical about his work ethics and plus he wanted to charge me for checking the code for the restr. perf. so i decided to take it somewhere else and was told it was the right knock sensor, but it comes on and off not every day though. that i why i asked if the fluid from the thermostat my be leaking on the sensors and causing them to malfunction. Any other suggestions please post. Other than that i will probaly have to replace the sensors.
mikiep
12-20-2019 07:37 PM
