Thermostat
can anyone tell me where exactly the thermostat is on a 98xjr? im new to jags and am no pro mechanic, but my jag that i bought a few days ago started to over heat. Im hoping its the thermostat and im getting the part later today. anyone have any tips ,suggestions on changing out the thermo. They would be greatly apprecieted. thnx
Drain the radiator. Refer to General Procedures. Retain the coolant drain tray in position to catch any spillage when removing the outlet pipe.
stepNum(0);
if(DanaFlushWrite) DanaFlushWrite();
Disconnect the bottom hose from the coolant outlet pipe.
1)
Release and reposition the hose clip.
2)
Disconnect the bottom hose.
stepNum(0);
Remove the thermostat from the outlet pipe.
1)
Remove the three bolts which secure the thermostat cover to the outlet pipe.
2)
Remove the thermostat cover, the thermostat and the seal from the outlet pipe. Discard the seal.
stepNum(0);
1)
2)
stepNum(0);
1)
2)
mikiep
12-20-2019 07:37 PM
