Thermostat changed but got restricted performance after???
i literally just changed out my thermostat for what ever reason it was different then the factory therm. so i had to do slight fabrication to the therm. cover nothing major that would effect the seal but now i have a restricted performance light out of no where...i pulled the codes and these are the codes that popped can anyone tell me asap what they are p0455,p1000, p0327
P1000 is a nothing to report code,
P0327 is knock sensor A Bank voltage low (bad connection or sensor)
P0455 is a fuel cap fault, try re-fitting it after clearing the codes and see if it comes back.
There's a how-to on replacing the knock sensors here,
https://www.jaguarforums.com/forum/x...ine-faq-45963/
Neither are coolant circuit related, but you could have missed connecting a knock sensor back up?
Hope this helps
Hope this helps
RidenXj8 (09-22-2012)
aholbro1
08-05-2021 05:02 AM
Aus V8S
11-13-2015 11:01 AM
