With these codes I'd assume I just have to swap the one ignition coil correct?
My xjr recently went into restricted performance and I was thrown these code which seem pretty straightforward, so all I need to do is swap the ignition coil on cylinder 3 correct? Does any have a diagram of the order of the cylinders?
