Things don't look good. Coolant leak, overheated, misfires and knock
Old 01-05-2020, 02:58 PM
OUScooby's Avatar
Originally Posted by AaronsJag
I hope things come out more simple than they seem! Electrical...faults... are where I start getting annoyed with a car, BUT may not be costly to fix. Just time consuming.
Just went to drive it up for the first time since putting in a new battery, I was imediately met with "restricted performance" on the dash and a CEL. Scanned the codes and got misfire codes p0306, p0307, p0308, as well as p1316 a jag specific code for rough idle, and p0357 "ignition coil malfunction." I'm wondering if I'm damaged my coil packs???
  #142
Old 01-06-2020, 10:54 AM
Jhartz's Avatar
Why are you posting on two separate threads?
  #143
Old 01-11-2020, 05:17 PM
OUScooby's Avatar
I'm posting in this thread to chronicle everything that is happening with my car, I started another thread to ask about that specific problem.
  #144
Old 01-11-2020, 10:01 PM
exjay8's Avatar
OUScooby....you are certainly going though a steep
learning curve and I hope all things turn out well in the end.
I have followed your thread since 2016 and indeed has been fraught with a few problems
which I'm sure you will put down to experiences both good and bad.
Let's hope it all comes out well in the end and you get to enjoy the reason
these superb cars were designed in the first place ;o)
  #145
Old 08-02-2020, 10:04 PM
OUScooby's Avatar
So one final update to this story. After getting the car back together and getting ti running smoothly I was never able to complete my registration to be able to drive it on the road legally. I could not take the smog test required to complete my registration because I could not get the readiness monitors on the ECU to turn over to ready. I tried every drive cycle I read about here and put over 1000 miles on the car trying to get the readiness monitors to pass (which is a very annoying task to do when don't have valid plates on the car and can only drive on one day moving passes from the DMV). I'm not even sure where the problem was that was preventing the readiness because I could not get it to throw a CEL or DTC. If I had a DTC it would at least point me int the direction of where to look to fix something but at this point I was out of thing to try diagnose and out of patients with this car. I was tired of throwing good money after bad with this so on Friday I took the car to CarMax and accepted their offer of $2000.
Many thanks to everyone who helped me on this journey. I may not have been able to complete it but I did learn much along the way, and I still really like these car and they way they look and drive. But I don't think I'll be trying my hand at owning one again. I wish things had worked out differently but this is where my story with this car comes to a close.
Thanks again everyone!
extheaterkid
10-03-2018 07:15 AM
bigbigbrig
04-09-2016 12:53 PM
innzane
12-27-2014 08:55 AM
jmcGoBlue
03-05-2012 11:41 AM
stephen11962
12-06-2010 07:38 AM
Quick Reply: Things don't look good. Coolant leak, overheated, misfires and knock
