Thinking about an 03 XJR, what to look for etc?
Thinking of looking at an 03 XJR with 60k on the odo. Seller wants 16k for it. What are the problem issues with the 98-03 XJR I know early engines had issues with the nikasil, tranny issues throughout (is a 5 speed swap doable on the car or will it cause a wiring computer nightmare with the osd2 system? What other issues are common to the car?
Also considering a plain jane XJ8 but favor the R. How far back can I go in the model years before hitting the early issues as I would expect that by 01 or 02 most of the intro issues would be solved right? Finally, anybody use one for light towing like a utility trailer and pop up camper. I'd use it for towing when needed.
Thoughts on the 04 and 05s? Beyond that I'm getting out of my price range. Most maint. would be done by me, only big stuff would go to a mechanic so running costs I should be able to keep down. What kind of pricing would you expect?
Thanks for your thoughts
Check out the FAQ on the XK8/R forum for:
'I’m buying a used XK8/XKR, what should I look for?'
Here is the link: https://www.jaguarforums.com/forum/s...ad.php?t=29800
The XJ series is the same drive train/electronics.
The 'early issues' were up to '99. They tapered off after that until the introduction of the 4.2L, 6 speed trans in '04 for the XJ series. The '04 introduced not only the updated engine/transmission but the restyled aluminum body which brought on its own set of concerns.
Personally, I would target the '02/'03 years if you prefer the steel body styling. All the significant issues had been resolved by '03. Latest year you chose to pay for if you like the newer model.
hunter34
19
09-14-2022 11:09 PM
Rlover
03-30-2016 10:04 PM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
