Thoughts on this...
Thoughts on this...
So I take the car out night before Christmas Eve and its accelerating with a slight skip, then I notice all my stereo settings are back to 0 (bass, treble etc) re submit them and after a visit to a store the same thing with the added bonus of an airbag light and it cranked a few extra revs before starting. After next stop, no airbag light, no hesitation, no messed up stereo settings. Car sat past three days and started right up this AM. After I left work it was hesitating slightly again. Then after a store stop, back to normal.
I logged out to see what that reply was (I thought it might actually be helpful, but alas, it was typical, know it all, Mark SF wannabe Mod) and only confirmed why Mark SF is on my "ignor" list. Bring something "positive" to the discussion, leave the mods job to the mods AND learn how the search feature really works, you can actually search "key words" in "Threads" or....wait for it...."posts" .....not just titles! AMAZING!
I suppose the first thing most people would ask is how old is the battery and how well charged is it?
Have you checked the fuses for the stereo? Is it base or premium system? I've noticed with these factory stereos the bass & treble settings can be set differently for each profile. So if I have radios bass at 6 I can switch to CD and it will be 4. Could this be the scenario with yours?
Don B (12-27-2016)
A couple of areas that will mimic the battery are the ground strap running from the engine the frame and the Bulkhead connector in the engine compartment. I would check and clean those along with a load test for the battery.
I had a similar problem and it was the ground connector corroded.
Don B (12-27-2016)
Take a look at the connections at the battery, and connections at the alternator. From there I'd get a charging system and battery check. Good luck!
EDIT:
Good call.
EDIT:
JTsmks (12-28-2016)
Thanks all, I checked all the ground strap, false bulkhead connectors the other day. Went to autozone and the battery was not only the wrong dimension but was over four years old and the wrong CCA. Put in the new on and it really his-cupped when I took off and kept up the hesitation. This really reminded me of a "water in fuel" hesitation. I was down half a tank so I pulled in Shell and put 8.5 gallons of premium V-power (only gas I run) took off and after about three miles it started running/accelerating better and then went to only occasionally hesitating. I came home and put a bottle of iSO/heet in the tank. I'll report back results after more driving.
JTsmks (12-28-2016)
As far as the thread title, it would read ..."thoughts on slow start, hesitation, intermittant air bag light, stereo audio setting won't stay occasionally, some times multiple cranks to start" Not my first time on an automobile Internet forum, I chose the thread title as it would spark curiosity and because the problems were multiple I didn't want to jam up the title space. I'm grateful for your input on the ECU drivability "relearn" but toutilage on forum thread titles isn't required. Cheers!😃
JTsmks (12-28-2016)
It's "tutelage", btw.
I like a real title (fwiw). Instead of Heet, try BG 44 or SeaFoam (or the Gamout equal). Sounds like dirty injectors. It would be interesting to note if you have any codes (maybe the guys who sold you the right battery can check). When I first bought my last X308, in 2013, it was hesitating badly under load: cleaning the MAF sensor, cleaning the throttle bore and plate cleared everything up nicely.
Stereo problem is ok now, right? More important than a title is feedback on how and when your problems get solved -- that's how we amateurs learn.
