Throttle body
#41
This is the link to the TB :
NEW GENUINE JAGUAR XJ8 XK8 XJR XKR Throttle Body Assembly C2A1470 | eBay
The sensor I had not come accross before, aftermarket but definitely worth a try....?
#42
That's a stupid price....
For that money I'd buy a second hand throttle body and have it reconditioned by someone reputable. Ie ASI. Then make sure you calibrate it properly before refitting.
Lets be honest here, nothing you do going forward will get you your money back from what you've done already. But that's no reason not to go back to basics and work your way through one item at a time.
Where are you located? Maybe you might be able to find one to borrow or swap from a wrecker or something?
There are probably a few forum members with old parts lying around too. I know I have a spare throttle body sitting here... but mine's from a 2000 with the electronic cruise control, not the vacuum operated one, so it's no help to you
#43
#44
If the car is throwing a lot of different codes, it usually points to a dying battery. These cars are VERY fussy about having good voltage. Check that the alternator is putting out the right voltage, (14.2-14.4) Check that the voltage at the battery is almost the same as at the alternator. If not, clean all the connections between battery and front of car; there are a lot of them. Also clean the two earth cables; the one from the battery, and the one between engine and body(underneath). If that doesn't fix the problem, bite the bullet, buy the proper battery for the car, charge it fully before connecting. Keep us informed
Stanners
10-23-2015 11:58 AM
FS[MidAtlantic]: XK8 A/C tube
deelli
10-22-2015 11:28 PM
FS[MidAtlantic]: XK8 Radio harness
deelli
10-22-2015 11:25 PM
FS[MidAtlantic]: XK8 A/C pressure line with switch
deelli
10-22-2015 11:19 PM
