Throttle body gasket
Either way should be fine as long as you very lightly smear the gasket on both sides with Silastic or similar auto silicon sealer, this will strengthen the gasket.
Dan, you pay for what you get, non oem = problems, there's a reason why I always stress genuine parts and not Botch Jobs. This statement above is exactly why I have to stress this, I've had to fix unmetered air leaks because of 'sealant' - supercharged Jags require the correct parts or you WILL be doing the work again....FACT.
xjrjag
09-27-2015 01:53 AM
