Throttle Body issues
Hey guys - question. i have a 98 xj8 with original throttle body. I am guesing becuase there is no sticker on the throttle body like I have read should be there if it was replaced by the recall. My question - can the originals be rebuilt or is it better to find one that is a recall replacement, purchase it and use it. I have rough idle and restricted performance. I unplugged the TPS and it went away, but came back again same day. I'm going to get some electrical contact cleaner and try to clean the contacts and see if it will help it. Any help is appreciated.
Last edited by GGG; 10-12-2012 at 06:15 PM. Reason: edit typo in thread title so it appears in searches
Look at post 1 in this other forum thread on the throttle body contacts repairs:
https://www.jaguarforums.com/forum/x...asy-fix-82342/
Jim Lombardi
Jim Lombardi
This link will give you all the information on the plug mismatch TSB and the throttle body TSB related to many of the throttle body problems with your MY car.
Under normal conditions I would have asked if you had codes I did not this time because I THOUGHT you had already pulled them and that was why you asked about the TB. To answer your question yes the TB can be rebuilt and I have that info on my page. Go out and get a code reader or barrow one you WILL need it again.
