Throttle position sensor
thanks Charlz. So I don’t need to scan it to check the throttle opening? Just feel it through idling?
Try for a simple meter reading of 0.50 volts DC on the Brown wire and Green wire at the proper idle stop as there are 2 TPS sensors in the package . From the 0.50 reading go + or - direction from there til you can find your sweat spot .
This can be adjusted without running the engine with the key in the on position . Test run to check the setting requires a road test .
See page 55 lower right corner :
http://www.jagrepair.com/images/Auto.../jagxj2002.pdf
ericjansen (08-02-2018)
The TPS sensor can be swapped out as the thread is outlining. The TPPS sensor on the other side of the throttle body though, that one isn't something that can be, unless there's some new magic I haven't found yet
If you look at the 2 wires that you read tho 0.50 volts at on the idle stop . Yon't want t see is a bip towards o volts as you slowly move it through their range .You can twist the throttle open an look for a open on the wiper brushes to see if you have a bad part out of stock . What you gon't want to see is 0 volts but a steady climb toward 5.0 reference voltage .
Stounedi
21
12-23-2017 06:33 AM
'05 STR
02-14-2016 08:33 AM
juha_teuvonnen
12-17-2014 09:35 PM
sws805
01-24-2013 10:58 AM
