Ticking in the engine
From the top of the engine, it does sound like injectors, but from underneath it sounds mechanical.
No VVT on the 3.2 so that isn't the issue.
How many miles? Have you tried an oil change, checked the front of the engine for sticky belts or ancillary bearings?
Failing that, it may need the valve clearance checking.
muttony
04-01-2018 02:29 PM
Nick Morrison
03-16-2018 10:17 PM
