Time sensitive question
Hi all, thanks for your answers in advance!
1998 AJ26 XJR dropped valve seat passe4nger side- I have AJ27 heads laying around do we:
1. Only replace passenger head with AJ27 head, or swap both sides?
2. should I keep the AJ27 camshafts with the AJ27 heads, OR do I use the AJ27 cams and swap the reluctor/gears?
THANKS!
Dave
THANKS!
Dave
Ok- here is what I have gathered:
1. cams from both heads have the same part number...so they must be the same size.
2. can use the AJ26 cams on the AJ27 heads since they are same part number
3. I was overthinking the process
4. Will use AJ27 heads with AJ26 cams and all should be right with the world.
I watched someone do it once. You must install the cam in a bench vise. This was a few years back but, I think he used a pipe wrench to twist it off and used a large brass hammer to install it. I'd highly recommend taking pictures of both reluctor positions prior to taking either of them off. Reason being is that if it's not clocked just right that it'll throw a CEL on. Then you'd have to reclock it while the cam is installed. Not fun. Take your time doing it because it's still easier than adjusting valves. Believe me!!
Hey all-
Just wanted to follow up on this. Used two AJ27 heads, the drivers side cam from the AJ26 (same part# as the AJ27 cam) and checked valve clearances- all to spec. Buttoned up today and although there was QUITE A BIT of noise for a little while, it smoothed out and is running quiet and like a champ.
Jimmy 68
03-17-2016 10:55 AM
