Timing chain bottom sprokets
I am changing the timing chains on my 2000 XJR. Everything is going better then I had expected. I did just have a question come up that I hope someone can help. When I removed the first chain going to the crank, I slid off the sprocket. I left the back one on. When I reinstalled the front sprocket, I noticed that the teeth on the sprockes where 1/2 tooth off from each other. I made sure I installed it the same way I had removed it (I think). If I flip it over the teeth line up. I also notice to dots on the sprockets. Do thay have any meaning?
Thanks for any help.
Scott
Scott
The following 2 users liked this post by pd_regan:
popeye68 (05-14-2011),
test point (06-15-2011)
Wolfy
05-28-2024 08:06 AM
RoyLittle0
05-25-2023 02:38 AM
