Timing Chain break
Old 05-14-2011 | 01:55 AM
nguyennhatquang's Avatar
Default Timing Chain break
today when i start the car. it start very difficult.
i plug in the diagnostic it said Multi misfiring. so i open the engine and i saw that. so will the piston will hit the valve ? what should i do now
what is the big mess i met and how much i need to pay for the part.
thank you in advance.
Old 05-14-2011 | 07:25 AM
Sean B's Avatar
Hello, sad to say it doesn't look easy to fix this. You will need to find out if the valves are damaged by taking the cylinder head off.
Old 05-14-2011 | 07:45 AM
jaginblack's Avatar
Price will largely depend on whether you are doing the labor or a professional and how far you want to go. I replaced all my chains, guides, and tensioners both primary and secondary, sent the heads out for an overhaul, replaced all gaskets, and some other parts like the coolant pipes. I also had the injectors cleaned while I was at it. I spent a bit over $2200, but did the labor myself.
I was lucky not to have any valve or piston damage damage which would have added a chunk. My chain broke on startup in the driveway. Sounds like you might have the same luck.
Old 05-14-2011 | 08:54 AM
hflavell's Avatar
Default Chain replacement
That's the secondary chain that is broken and I can tell you how to replace it for under $100. The real problem is what other damage do you have. With out actually replacing the chain I am not sure how you can tell with out taking it further apart. Here is how I replaced my chain
https://www.jaguarforums.com/forum/j...my-turn-52434/
Look at the second page to see in detail what I did for the chain. Looks like your tensioner is the latest metal one which must have been replaced at some point. Was the chain stretched then? I can see the flat part of the exhaust cam and not on the intake cam. Which means there probably is further damage.
LoysJag (07-10-2012)
Old 05-15-2011 | 03:53 AM
flay's Avatar
What year and mileage was on your car? Just to know when it will happen!
Old 05-15-2011 | 09:27 AM
it is 140.000 miles
RoyLittle0
05-25-2023 03:38 AM
SD96XJ6L
01-12-2022 05:30 AM
Shawn Svacha
11-04-2019 03:47 PM
Bowman
09-15-2015 07:54 AM
Bowman
09-03-2015 04:17 PM
Quick Reply: Timing Chain break
