Timing Chain Job Update
Does the wining keep pace with acceleration and disappear at higher throttle, or go away completely? I had a wine that increased in pitch with acceleration on my BMW. The idler pulley and tensioner pulley on the drive belt were on their way out. I replaced both along with the serpentine belt and it was gone. From everything I've read and my experience followed suit, the passenger side secondary timing chain tensioner is usually the first to go. Not sure why as the configuration is balanced. The secondary chains are the ones that connect between the cam shafts to keep them in sync. The sprockets, chain and tensioner lie about an inch below the surface of the bell on the front of each valve cover. The Tensioner fits between the chain loop and is located almost dead center. When it goes, it tends to produce a distinct knocking sound (usually getting more pronounced as the car warms up). Use a stethoscope or the old screwdriver to the ear test and check for a knocking at these locations. Every component I had except the chains had significant failures and the only evidence I had was a pronounced knock under the passenger side valve cover.
Mine changed pitch with the accelerator and didn't disappear. The bearings on both the idler pulley and tensioner pulley were on their way out. The the whine increased in pitch the higher the rpm's. Made it sound like a turbo unit spooling up. A buddy of mine gave me the BMW for my daughter and it came with the whine, he said he'd been trying to troubleshoot it for a while. It's possible that you may be experiencing the early stages of bearing failure and only noticing it at idle. The pulley's are relatively easy to get to, you could pull them and give each a good spin. If they free spin, the bearing is bad, they are packed bearings and should feel somewhat snug but smooth when you spin them.
Here's a link YouTube - Jaguar V8 Potential Rod Knock It's not the one I originally found that was identical to what I was dealing with but definitely lets you know the sound. I'm not sure exactly what's going on at the beginning of the video, but towards the end when the engine seems to settle out you'll get the best example. Note: the original video I found, and my experience was that the knock wasn't noticeable on cold start up, but became audible after it started to warm up. If you've got a knock, use a screwdriver to your ear. Prominent knock from either of the bells on the front of the valve covers and I'd say you probably have a tensioner going (if 1 I'd bet all are getting ready to go or just as bad) There are 4 chains ( 2 on each side - 1 primary / crank to cam 1 secondary /cam to cam) the tensioner and/or components press against the chain about midway each case. If you loose tension the chain gets a little slack and can slap around behind the cover, that's the knock.
Did he ever pull it apart to determine what was causing the knock? Sounds like a rod slapping up against the side of the pan.
Happened to me on a 67 Camaro. It was only a matter of time before the rod let go and the piston went on it's way. When I pulled the pan, I could not believe how close it was to taking flight.
Scary.
Scary.
Yeah, I'm not sure what that racket is at the beginning of the video. Toward the end of the video it sounds like the car settles in, and there's a distinct pulsing knock. It's hard to say where it's coming from but a similar sound that's coming from the front of the valve cover is the tell tale sign of a bad tensioner.
Tools Used
Here are some pics of the tools a friend made up for me. The big bar looks somewhat like the sprocket tensioner tool but was made to hold the Crankshaft while working on the harmonic balance pulley. My sprocket tensioner is the disk with the extended nut on it - worked great with a breaker bar and a deep socket. Cam locks are 3/8 steel bar w/ hardened bolts. I used a small stack of washers under each bolt head to adjust bolt length. The only spec. tools I bought were the shims (could have made my own but couldn't find exact specs) and the crank locking pin.
Thats Helpfull
#28
XKRHottJag (04-09-2011)
Awesome Plumsauce
Thanks My mechanic and I did not see eye to eye on this one. I talked to Jag and they insisted that all the chains tensioners and guides be replaced. My mech protested that this was not the case and that he is confident that he can change the up tensioner without taking have the engine apart.
You help is much appriciated!
#30
Just make sure your mechanic understands the importance of, and the methods of maintaining the cam timing. If he has not done this before, you might want to think about whether you want to be the guinea pig. This is because you said he is "confident" not that he "knows from experience".
#31
Sometimes there's a reason
Earsti (04-11-2011)
#32
We my car was really weird it ran like a top we did a fully tune up because i did not know the history of it, and sure enough it really needed one. After the car was assembled again it ran like crap with that tensioner noise. I am just hoping that its only the top one and the performance is not there.
If the tensioner breaks does the car still run ok aside from the noise or did mine slighly jump timing? Or does your car also run and perform rough because the cam tension is just not there?
#33
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
