Timing Chain list of Parts Please!
OK, Iv'e manned up enough meat of my bones to take on the Timing Chain Challenge, the challenge of sweat, grueling agonizing train of thought, and sore fingers. My question now is, what do I need? Here is a list of what I think Ill need.
-cam locking tools
-4 METAL tensioners
-obviosly I have the socket and ratchet asortment
-maybe a new water pump
-deffinetly a new thermostat
-But do I need new chains since I've seen other member only replace the tensioners and guides
-and guides
This list I am aware will be costly, but much less costly than having Sir. Jeremy Sheffield of Manchester to do this for me for 22802587 pounds and 2 shillings. Or in the US (Im American)2582539782537892530789253978 worthless dollars. Little joke to lighten my stress as Im only 17 doing this job on the weekend.
-cam locking tools
-4 METAL tensioners
-and guides
Hi
Christopher's Foreign Car Parts -
JAGUAR V8 1997-01 COMPLETE TIMING CHAIN KIT, EVERYTHING
*http://stores.christophersforeigncarparts.com/** *-strse-100/Jaguar-tensioner%2C-Jaguar-timing/Detail.bok*
Complete Kit Upper & Lower Chains, Tensioners, Guides, Blades, Cam (Valve) Cover Gaskets, Spark Plug Seals, VVT Seals, Front Crankshaft Oil Seal & Front Timing Chain Cover Gaskets Total price $649.
Posted on their website -
THIS IS A COMPLETE TIMING CHAIN KIT,EVERYTHING YOU NEED
ALL 4 CHAINS
ALL 4 TENSIONERS
INCLUDING THE IMPROVED METAL CHAIN TENSIONERS
4 LONGER BOLTS FOR THE UPPER METAL TENSIONERS
ALL 4 NEW METAL DESIGN CHAIN GUIDE SLIDES
VALVE COVER GASKETS
SPARK PLUG SEALS & VVT SEALS
FRONT CRANKSHAFT OIL SEAL & FRONT TIMING CHAIN COVER GASKETS
I purchased this kit last year for our 2001 XJ8.
Jim Lombardi
ALL 4 CHAINS
ALL 4 TENSIONERS
VALVE COVER GASKETS
Jim Lombardi
Well thanks guys, luckily there is a man down the street from me I met just yesterday and he'll let me borrow all of his Jaguar special tools!!!!! He owns 11 Jaguars so he will deffinitly be at the top of my list for maintenance aids.
----and what is the deal by only working on 1 bank at a time and need using cam lockers?
Hi travolson
You can buy the metal thermostat tower kit ($ 75.95 - tower & thermostat) and the water pump ($ 76.95 - ask if the gasket comes with the pump) at Welsh Enterprises:
Welsh Enterprises - New Jaguar Parts, Used Jaguar Parts and Accessories - XK120 - XK140 - XK150 - E-Type - MK - XJ6 - XJ8 - XJ - XK8 - XK - XJS - S-Type - X-Type - XF
Also there is a great DIY on your Tensioner project with step by step instructions and photos:
Tmingi chain and tensioner replacement
Jim Lombardi
Jim Lombardi
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
Bcrary3
08-31-2015 11:29 AM
