Timing Chain Piece of Mind
Wrapped up my timing kit install today. XJR runs awesome and so quiet. The old guides were cracked. Tensioners were cracked but still intact. The chains were obviously stretched and I think the tensioners were maxed out. Glad that worry is over. Now i know what was in the and now gone.
If you dont know the condition of your timing components, go ahead and replace.
I got my kit at Motorcarsltd.com.
Jaguar Xj8 2000 Engine Timing Chain Kit
I installed the metal upgrade kit
I worked on it off and on over a 2 day period. A couple of collant bleed hose connectors were not so cooperative. Had to get those. Supercharger belt was worn out. Replaced it.
Kits vary. I got the one that had updated metal tensioners ,new guides and chains. Came with timing cover gaskets and new crank seal.
kit retails for about 500-600 depending on where you get it. You will also need valve cover gaskets and sealing rings.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
