Timing Chain Replacement - Won't idle!
Find the hiss, find the miss! Look at the part load and full load breather tubes carefully for splits. Check the plenum and it's joints. If you can hear it, you should be able to find it. Some folks use a piece of tubing stuck in their ear, stethoscope style and run the other end along the engine to listen for the leak.
Jhartz (03-21-2016)
Anxious Jim
01-13-2015 08:06 AM
korvetkeith
07-05-2013 03:05 PM
ahauber
11-12-2012 07:24 AM
05Blkstr
33
12-19-2011 10:30 AM
ahauber
09-07-2009 12:47 PM
