Timing Chain Tensioners
Right now I'm fearing the worst. It started off as a heater supply and return hose R&R, some fresh fluids and all is well. Ran well for 2 days without a hitch. Then at idle in my driveway it stalled and after a few attempts I stopped to pull codes. It had a different sound that smelled of timing.
Long story of it I've removed the cam covers to inspect what I could see of the tensioners and found several 1/2" pieces of what used to be a tensioner in the upper portion of the housing. Who knows what might lurk in the bottom. How likely is it that it jumped a tooth throwing off the timing and not done any significant damage to the motor. Its been well maintained and has
140k and was running smoothly without a rattle.
I know that I have to pull the front off the motor as evidenced by the plastic pieces but is there a way to determine if that is what happened without going deeper i.e. skipped tooth timing issue. Thanks to all that may wish to keep all Jags purrrrrin.
Received 1,794 Likes
Aloha...
If you don't have one, find someone with a bore scope to look down in without removing the covers. Its almost assured you'll have to take it off though. Don't be too concerned, its really not that bad, just time consuming. You can take almost the whole front off with 8mm and 10mm sockets. If your going to use a cordless drill to remove the parts, I got an angle attachment head, it makes it go quicker.
Your going to need to determine chain replacement (most likely) also. Take your serpentine off, take out the plugs also (its easier) and use a breaker bar on the crank pulley. Rotate it slowly until the cam lobes are flush on top, check both sides at the same time in case one jumped, but both sides should be flush to be in time. There a many, many threads on the chain tensioners, do a search and research them. Know before your go.....
BTW, I'll be out your way in December for the 75th anniversary of Pearl Harbor. I plan on doing a little island hopping.
The quickest check for a timing issue is to do a compression check. If you find cylinders with extremely low pressure or no pressure it is a valve being held open by the timing being off.
If the compression is good then odds are the valve timing is correct and hasn't changed.
As a minimum if you find timing is good I would change out the secondary tensioners and remove the oil pan and clean out the debris. You should be able to get a look see down the timing cover for a visual of the primary guides for missing pieces.
Mahalo
