Timing Chain too tight?
No Timing Chain slop. I am installing new chains and tensioners on my XJ8 and don't have any chain tension to adjust. It's so tight I'm afraid something will break when I start it. The chains are same length. Tensioners have thicker plastic runners than the old broken ones. Am I missing something?
I got mine from Christopher’s foreign car parts, and my primary chains were very tight as well I couldn’t even get a shim in between the tensioner and the guide but I asked my go to mechanic and he said as long as it’s tight you should be good and mine are fine and I’ve put on a 1000 miles since but I don’t know why they were that way and I don’t wanna tell you it’ll be fine because idk if yours will be. Make sure you have the CRANKshaft sprockets on correctly as well as I forgot to check that when I did mine.
