Timing chain tools
If you can find someone close to you who you can borrow the tools from, that would be great (you don't say exactly where you are located, there are many Marlboros), that would be ideal, but if not, you will need to purchase two tool sets.
The camshaft/tensioner/crank positioning alignment set is available from several online sources for $50 or less. Here is just one example.
And the more expensive crank holding and harmonic balancer puller set is available here, at a pretty decent price.
You can purchase all that is needed for less than $200.00
dan02xk8
03-30-2019 10:41 AM
popeye68
02-02-2014 06:54 AM
slanham
General Tech Help
02-01-2014 06:34 PM
97Aggie
01-13-2009 08:11 PM
