Timing off? Tensioners? help
Hi XJRman,
Viewing and listening to the video, it does sound like you have a tensioner problem.
I would not run the engine now until you remove the cam covers to confirm that you have the plastic tensioners. If in fact you find that these are the 1st generation ones then the 3rd generation ones are readily available on eBay or elsewhere on the internet.
Please add you Jaguar details to your signature including the year and mileage along with any other details that you want to include. This will help us out with regard to any issues that you have with your car.
Thats sounds scarily like the noise I'm experiencing. Check out the video on my thread...
https://www.jaguarforums.com/forum/x...arm-up-101702/
The recording level (gain) was turned way up on my camera so it sounds much louder than your noise, but the tone and rhythm sounds identical. You're recordings sound quality is much better than mine.
I agree with AVT. Remove the supercharger belt and listen again. Also I suggest putting a stethoscope or screwdriver against various points on that side of the engine and listening to see if you can narrow down the location it's coming from.
I'm taking the rocker covers off this weekend, checking the tensioners, sticking a bore camera into the engine to check the valves, rebuilding the front suspension, installing a replacement rear diff and getting the old girl MOT'd.
If I find anything to do with my noise I'll update your post as it could be the same issue. I'll also be keeping an eye this thread so keep us all updated.
Another strange sound is that of compression leaking past a loose spark plug. Happens in the best of families. Compressor and accessory drive belts off next.
Couple recommendations for a new owner without complete documentation of maintenance and repair history. Both the original plastic cam chain tensioners and overheating of the engine will kill it dead right there (DRT).
Without clear documentation of the tensioner change you are going to have to pull a valve cover to verify that yours are metal. Your car is old enough to have had the original plastic tensioners replaced with new plastic tensioners. My '00 had that done at 40k and 80k miles and I replaced them with metal at 106k.
Without clear and current documentation of coolant system maintenance you should change the water pump, thermostat, and coolant. While all this is going on check all the hoses for softness. Your XJR has additional hoses under the compressor that are a bear to replace.
I forgot about the sparkplugs.....bosch aren't they?
I may well take you up on that. I'll be in a better place this weekend after I've had time to check everything. If I find anything I'll let you know. Otherwise I'll request that video.
When I first got the car, the dealer said that they replaced both water pumps, the ignition coils, the spark plugs( i dont know which brand) and a couple of hoses(i dont know which ones). Is it a possibility that maybe the spark plugs are loose? Or could it be that maybe they arent the best brand?
RoyLittle0
05-25-2023 02:38 AM
