Tips for remvoing stuck valve covers (cam covers)?
I'm trying to get my valve covers off but it appears they are "glued" on by the the old gasket maker. I don't reall have room to get a blad in between to cut the gasket maker apart, and I'd also be wored about scoring the machined surface.
Any one else experience this? Got any tips?
Are you absolutely sure that all 14 bolts (12 parimeter 2 in center) are loose?? Those 2 center ones are a little bit hidden. If they are all loose but still not letting loose, I'd maybe tighten at least the 2 centers, loosely install the coils and run the engine to operating temp at idle to see if the heat releases them.
Can't idle the engine, no coolant, no oil and intake off and supercharger is halfway off.
The gaskets do not call for RTV except the little dabs in the front.
If you are sure that all the fasteners have been removed, a smart thump
sideways with the side of your fist usually does it.
You don't say how many miles or even what year, so it is pointless to
speculate about accumulated varnish.
I feel silly, but its off now.
Now I can tell you: I was going for the crowbar when I decided to take one more look for fasteners, found one I had missed and off it came, easy as can be.
Vector
aholbro1
03-11-2023 08:45 AM
Peter36
07-06-2016 08:52 PM
webbeing
06-24-2016 11:10 AM
