Tire size on 16 inch standard rims
Well I'm not sure what will actually clear in the back, where you typically run into issues plus-sizing is near full-lock on the front tires....
The factory rims are pretty wide, I know there's a 16x7 and 16x8 factory wheel, mine are the 16x8's, which can hold quite a bit of tire...you're going to want to keep the overall diameter pretty close though for clearance and to keep the speedometer close to accurate.
I would imagine the car could clear a 245/50R16, which is two steps wider and one to two steps lower in profile. Also that's a popular enough size to give you some options.... The next widest step that has fair availability is a 275/50R16, which is a LOT wider and taller and would most certainly rub, at least on the front if not all the way around.
bigcat777 (10-14-2013)
metalmarty
09-11-2015 07:05 AM
