Too much boost, too weak head gaskets
#41
Me too plums, see pic, fuelabs - centre - bottom, Mine runs 53PSI at idle, vacuum port plugged, and about 78PSI at full noise - ( 2x new Denso fuel pumps) It ran lean on the dyno, raising fuel pressure was something I was going to try.
Another thing was to fit a pair of oxy sensor manipulators, same as I have on my Ducati
PERFORMANCE BOULEVARD - O2 Manipulator
#44
#45
#46
the flow rate of the pumps, has never been measured, also the injectors have been cleaned, but not able to be flowed in the town I live in. I have an aftermarket MAF, which has a mind of its own.
If indeed the problem is that the pumps or injectors physically can not supply enough fuel - no amount of oxygen sensor manipulators or electronic trickery will alter the problem. The idea of the manipulators was to fool the ECU into thinking it is lean, which in fact it is through all rev ranges, and get it to supply more fuel.
There is an old dyno here on a post, showing around 13.8-1 @3500RPM improving to about 13-1 @ 6,000RPM.
I don't think I've suggested that it runs out of fuel,
#48
#51
#53
BTW, XJR99, I have a near-perfect spare 17x7.5" rim to match those shown in your trunk, with Pirelli P6000 tire, so it will work on XJR 18", OR, with OEM tire on XK8, I think is the other application for these rims. Think it has been on ground once, but not for long, as both tire and rim are as near-new.
EHT/Aiken, SC
EHT/Aiken, SC
#55
FS[Western US]: parting out 1999 xj8 vandenplas
bavareze
09-11-2015 01:49 AM
1964Daimler
09-09-2015 11:20 AM
