Top horsepower?
Old 06-12-2014 | 04:20 AM
XJR-99's Avatar
Please wait until the weekend. I go to 1/4 and full mile competitions. Bad luck this spring: First session weekend I lost for my wife and the next one was rainy. I am preparing MEGA EXTERNAL COLD SCRAM INTAKE SYSTEM - as you can see. Last year I just removed the inner headlight. Now the STAGE 2 system has been fully developed in the labs and ready for serious action. Waiting for GRAZY numbers. Videos will be shown.
Attached Thumbnails Top horsepower?-mega_cold_intake.jpg   Top horsepower?-big_snake_1.jpg
WaterDragon (06-12-2014)
Old 06-12-2014 | 04:36 AM
Dan Hiatt's Avatar
Now THAT set-up would be hard core!
Old 06-12-2014 | 04:39 AM
XJR-99's Avatar
Some wheelie expected. 220lbs extra load in the trunk keeps the feet up.
Old 06-12-2014 | 10:28 AM
WaterDragon's Avatar
Awesome !
Scramjet technology! Scramjet - Wikipedia, the free encyclopedia
Old 06-12-2014 | 12:04 PM
Lavaman's Avatar
Hahahahahahah.. That's the dumbest thing I've ever seen.. Too bad it's pointless
Old 06-12-2014 | 12:30 PM
XJR-99's Avatar
Will be patented soon.
Old 06-12-2014 | 12:51 PM
SteveM's Avatar
Should I be worried?
  #28
Old 06-12-2014 | 01:00 PM
XJR-99's Avatar
Always
Last year's event: http://www.cruisingnight.fi/index.ph...=32&Itemid=137 . Check from 5:10 . Won the Eaton powered Opel by 3.5sec.
Old 06-12-2014 | 01:51 PM
ccfulton's Avatar
Originally Posted by grandell
It's not like anyone ever dyno's their car to get a true figure anyway, or they add in a 'transmission loss factor' which is just a made up number.
Someone did...
328rwhp to 454rwhp by installing a twin screw and nothing else, not even a better exhaust.
https://www.jaguarforums.com/forum/x...n-screw-96101/
I did almost all of the work myself, and don't want to even think about what it would cost to pay someone else to have done all that custom fitting.
The car is a blast, but the project is not for the feint of hear or thin of wallet.
grandell (06-12-2014)
  #30
Old 06-12-2014 | 02:23 PM
Dan Hiatt's Avatar
That was awesome! Very little wheel spin, she just hooked up and went. Nice!
Always
  #31
Old 06-12-2014 | 02:37 PM
XJR-99's Avatar
That airfield is very, very slippery if compare to real drag strips and just a few cars went 60ft under 2sec . New drag radials helped me for 1.963 ( you can see it if stop to 5:34. ET was just 12.80 because of grazy rich mixture. Now, with wideband lambdas in both banks, the right mixture has been finally found.
  #32
Old 06-12-2014 | 04:23 PM
Originally Posted by ccfulton
Someone did...
You did a beautiful job on your build and posts!
When you say only Twin Screw at 21 psi and nothing else was changed, what you really meant was a twin screw and:
larger MAF
larger intake
larger TB
Custom elbow
Custom fuel delivery
Stock rear end?
Water/meth kit
Additional electronics for the TB
328 rwhp to start- So you have a 4.2 and not a 4.0 right?
+126 HP gain is a transformative amount of gain The car must pull like a freight train now.
The following 2 users liked this post by WaterDragon:
ccfulton (06-12-2014), grandell (06-12-2014)
  #33
Old 06-12-2014 | 05:08 PM
grandell's Avatar
4.2 + water/meth is kinda cheating Fantastic to see actual figures though! Thank you so much. I'm looking forward to reading your build thread through properly.
  #34
Old 06-12-2014 | 08:53 PM
ccfulton's Avatar
larger MAF
larger intake
larger TB
Custom elbow
Stock rear end?
Water/meth kit
Ok, to be completely correct, I installed the twin screw kit. That kit included the intake elbow, larger TB, intake tube and MAF.
Nothing unusual about the fuel delivery, although if I was doing it again, I'd upsize the injectors, since the 32 lb/hr stock ones are approaching their limits.
Stock rear end for now. Looking at a LSD, and thinking to do some treatment to the ring and pinion for strength while it's apart.
  #35
Old 06-12-2014 | 08:57 PM
ccfulton's Avatar
Thanks.
I can't really fault the car for coming out of the factory with a 4.2L.
And the water meth really didn't make any difference in the power, it was exactly the same with and without it in the baseline run. I mostly have it for added safety factor and it's set to only come up at pretty high boost (~15psi) so one fill up of the tank lasts a good while in "normal" driving.
  #36
Old 06-13-2014 | 01:10 AM
avos's Avatar
It's 126 rwhp gain, and that translates to about 150 HP extra (assuming a 17% drivetrain loss).
That's not the limit of the twin screw Kit, I was able to pull about 210 rwhp more (so about 250 HP), but requires some more (relatively cheap) mods of course.
  #37
Old 06-13-2014 | 05:57 AM
sparkenzap's Avatar
Avos:
Please remind me your LSD setup?
  #38
Old 06-13-2014 | 04:40 PM
grandell's Avatar
Was OS Giken, wasn't it? The other option is Quaife
  #39
Old 06-14-2014 | 01:44 AM
avos's Avatar
The diff housing/gears/bearings are stock, the inner part is indeed a clutch type OS Giken TCD diff.
For 500 rwhp with a LSD I would certainly recommend to give the pinion/gear a shot peen treatment.
  #40
Old 06-14-2014 | 11:45 AM
XJR-99's Avatar
It was real Street SLIDE today. Results: !%#&/()&%%% . +10C , 10m/s headwind, 90% humidity and finally rain ended the event. I was some of the latest who run in small rain and felt it very dangerous after 660ft... Today's best 330ft was 0.45s slower than last year on the same event. 110lbs of extra load in the trunk did not help.
But anyway I won easily all the three races: Firebird ( the red one in the picture ) , Corvette and Chevelle.
Stage 2 intake got a problem since just 85mm pipe goes throught the hole of the headlight, so I did not use it
Attached Thumbnails Top horsepower?-street_slide_2014_1.jpg   Top horsepower?-street_slide_2014_2.jpg
Quick Reply: Top horsepower?
