torque converter drain
Would anyone know if the torque converters on the 98-03 XJRs all came with drain plugs? Do they refill by adding transmission fluid as you normally would when changing the fluid? Or, is there some procedure that should be followed when draining/refilling the converter?
jaguarcraver (02-24-2013)
aholbro1
08-05-2021 05:02 AM
chatmanx
09-11-2015 07:17 PM
