Torque converter - Should I seek a second opinion?
Guest
Posts: n/a
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Our Jag is a 1999 XJ8. My husband was driving it on Saturday - stopped at a red light, and when he tried to go, there was a lurch and then the car wouldn't go. (Apparently it went into limp mode.) The check engine and transmission fault lights came on. He says that it seemed a little louder than usual when he was on the highway prior to this. He "limped" the car into a parking lot and says it seemed louder then. Reverse works fine. We had the car towed to our neighborhood repair shop, and then they told us to take it to a nearby transmission shop, which we did (another tow). The place is part of a chain, but our regular shop recommended them highly. Online reviews are mostly good, but not entirely. Both shops pulled the P1722 code.
I've read all the bad transmission threads I could find here, so when I initially talked to the transmission shop guy yesterday, I asked him to please check the various sensors, harnesses, etc. He called me yesterday afternoon and told me that they'd been able to drive the car a little just to see what it was doing, and that he knew that the problem was a bad torque converter. He said that he knew this because he could hear it. I asked if he had checked the sensors, etc. and he said that he had not because this would be a waste of time and money, since he already knew what the problem was. He quoted me a price of $795 to take everything apart, and he said that "this kind of repair usually runs around $2000," (which would include the original $795). I forgot to ask about warranty, which I will do today. But I guess my biggest questions relate to his findings. Do my car's symptoms sound like a bad torque converter? Is this something you can hear, and if so, what does it sound like? Does this necessarily rule out the possibility of a simpler/cheaper fix? Should I pay for another tow and get a second opinion?
Thanks in advance for any input! Oh, and if anyone has a recommendation for a shop in the Atlanta area, let me know that too!
Hope someone can help you out with your question Georgia (I assume the state, not your first name). There are a few members in your Atlanta, if you look in the regional section, you'll see them. If you post there, they may be able to give you some advice on a good jag mechanic.
If you plan on sticking around and frequenting the forums, please stop by the New Member area and introduce yourself and your car.
Replaced my torque converter, but never heard any sounds from it. The Tach was hunting up and down about 300 RPM's when cold.
I would have this estimated at a Jag dealer also. If the dealer is within $300 of the local guy, it's a piece of mind knowing there is more support behind the repair.
aholbro1
08-05-2021 05:02 AM
WinterJag
16
10-09-2015 07:49 PM
chatmanx
09-11-2015 07:17 PM
