Tough time filling up gas tank
Somewhat suddenly, I am experiencing a problem filling up my 99 XJ8 with gasoline.
As I am filling the tank the nozzle constantly "clicks off" as if the tank was fuel but it it not. The fuel seems to be backing up the filler neck and then drains down - then I start the process again. I have tried different gas stations with no change...
I can eventually fill up the tank but it is a rather cumbersome/frustrating process.
This could be related to the emission codes the ECM keeps flagging (P0455 & P0442 - Large/Small evap leak).
Any advice/help you can offer would be appreciated!
Thanks....
Thanks....
i had this same problem. The attendant at the station said to lift up the nozzle slightly after putting it in the fuel filler neck. I tried it and it works! I am guessing that the auto shut off is triggered sometimes, and doing this overrides it. Has always worked for me since then. good luck!
I've tried that to the point of spraying fuel all over the place :-).
As little as a month ago I've had no problem with this.
As I fuel it, it seems to be spiting back the fuel up the filler neck.
I had that problem in a non-Jaguar vehicle and it was related to the cannister that absorbs the fumes from the tank. It also absorbed the gas overflow and spillage during filling and ended up plugged in some way.
I removed the cannister and filling returned to normal. I don't recommend doing that, especially in your Jaguar, but it is probably the cause of your problem filling the tank.
The dealer can fix you right up, no doubt.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
The cannister close valve (CCV) is located aft of the RH emission control cannister on X308. When functioning properly, it is in the open state when the vehicle is shut down. Pressure inside the fuel tank during refueling is vented through the CCV.
The Jaguar factory part number for X308 applications is LNC1525AC. XK uses a similar valve, but the mounting bracket and therefore the part number is different.
I have seen a number of these valves fail on both XJ and XK, and when failed in the closed position they will inhibit fueling in the manner described. Don't blame Lucas please, I believe it is a Denso component. No fault code will be logged in this instance, as there is no emission system leak: even when there should be one, when the engine is shut down.
There is no specific factory bulletin for this problem to my knowledge. I first found the problem on my own when investigating a customer complaint of slow fueling: cleaning and lubricating the valve while hotwiring it to cycle restored the performance, but it failed soon after. I have since seen the problem many times, and you will read of other technicians who have repaired this fault if you research the Forum archives.
Conversely, there are factory bulletins pertaining to CCV valve failure that will initiate emission control system leak fault codes to be generated. That's what happens when they don't close fully, or fail in the open position.
If you can get under your car, and have a set of torx bits (T27?) and a pair of pliers, you can replace this valve yourself. Jaguar list price for the CCV to suit x308 is $51.25.
You will not find an aftermarket replacement, and you can PM me to order one if your parts supplier is quoting you a higher price. The only way to verify the cause for certain is to test the valve, but that diagnosis fits your symptoms and the common failure pattern.
tadpole (08-06-2011)
That could explain why I was getting a "major leak" code when I was able to fill the gas tank no problem and now I get a "small leak" code.
I have a 1999 XJ8. How much effort is involved in changing out the CCV valve? i.e. do you need special tools? Should I take it to a dealer to be done?
I am pretty handy and have done other work on the car (i.e. changed sec. chain tensioners). Just want to get some idea what I would be in for :-)
Thanks so much...
Thanks so much...
I think you are taking me the wrong way... I wasn't insulting you, from reading your other posts I definately know that you know what you are talking about.
I most definately appreicate the expert advice, I really don't know if the purge and canister close valve are the same thing. I know where the purge valve is (I see it under the hood), I just didn't know if there was another valve down stream somewhere.
Sorry if I came across as insulting, didn't mean to.
Thanks...
Thanks...
It makes things more clear when you do alot of this stuff...a 2004 and later XJ8 is vastly different than a 2003 and earlier XJ8. So I get accustomed to calling yours an X308 and the later car an X350, but it's supposed to eliminate confusion instead of creating more. We're on the same page.
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Cats rule .....Dogs drool
Ronmexico - It may depend on which gas tank and EVAP system your XJ8 has, but there may also be a vapor vent valve attached to the side of the tank which closes the vapor system from filling with liquid fuel during refueling. I think it is very rare, but if it fails, fuel can fill the evap system and saturate the carbon cannisters, which may have been what was described in post #5 earlier. Anyway, I believe this can also cause some refueling problems similar to yours, so if the CCV is fine, maybe check there.
JTO - if the refueling problem happens as a result of CCV failing in closed position, then there should be no emissions leak codes register because there is no leak. If fails while open, there could be a leak code, but operations should be normal, including fueling. CCV should only close when leak test is being performed. Is it possible for leak codes while CCV stuck closed, assuming no non-CCV failure related "leaks," and still have refueling problem? Also, if you were referring to the unfortunate results of a 3 1/2 year old's first attempt at exiting her new booster seat by herself while holding her crappy sippy cup filled with fruit punch, then yes, the passenger seat has gotten sticky and there are footprints on the headliner. How else would that happen?
H20 - I loved Tech so much I went there, twice.
