trac/asc not available XJ8L 2000
Guest
Posts: n/a
I have the above mentioned Jag. For the last couple of days I started to get this msg. It happens after I drive for about 10 min and then the amber light gets on. I drive every day, but just locally and that's why I have only 35,000 miles on my car. Unfortunately, my car extended car coverage just ended, 2 weeks ago. (( Otherwise, car is fine, no problems driving.
Thank you very much for any input.
I suggest you find out what codes are stored in the ECU first, and I can try and suggest what might needs to be fixed. Either ask your Jaguar dealer to read the codes and tell you what they are, or use a hand held 'generic' code reader. Post ALL the codes here and I can see if I can help!
mikiep
12-20-2019 07:37 PM
jimforrest (uk)
02-28-2019 06:42 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 11:32 AM
