Trans leak help identify pls
Just found this leak and in the one picture there's what looks like a electrical connection that's looking pretty wet. Would this have anything to do with the P0715 Input Speed sensor issue I've been having recently?
See the plug about mid way on left... what is it?
Transmission fluid leaks can occur for various reasons, such as damaged cooling lines,
worn gaskets, and cracked seals. Tracing the causes of these leaks can be difficult.
It is very important to address them quickly and determine the fluid level in your tranny.
Low fluid levels can cause damage to your Jags’s transmission system. Some members
have found the issue is the cooling lines leaking where the pipe becomes a hose. The
crimps there were reported to be of low quality and cannot be tightened up.
motorcarman (Yesterday)
BONUS??? 😆 🤣 😂 nooo, the headliner coming down just prior to finding the leaks was the bonus!!! Never a dull day.
I'll look closer and ck the power steering. The engine oil ... wonder if its related to the tensioners that were just done? Didn't have any least before that. A full inspection is scheduled next week.
The power steering was over-filled but i couldn't find any traces of fluid anywhere. All I see is in the picture.
Oddly the last 2 days I've not had the gearbox fault or limp mode. I've been going through the gears before driving so maybe that helps.
Or
I have a car that needs Viagra.
The oil leak or leaks yet to be identified. No sign of any source so fa. If I spot anything related to the tensioners the dealership will hear about it.
jekyllman
General Tech Help
01-26-2023 10:28 AM
