Trans noise
Don B (03-25-2019)
Received 13,379 Likes
Transgo 5HP-24-PR Kit
Suitable fluids for your transmission that I have been able to confirm include:
ZF LifeGuard 5
ESSO LT 71141
Febi Automatikgetriebeöl Nr. 29738
VW/Audi G 052 162 A2
Pentosin ATF 1
Ravenol ATF 4/5 HP
The best price I have been able to find on any of these is on the Febi, from various eBay sellers, at just under $50 per 5 liter jug with free shipping.
The longer you avoid this necessary maintenance, the more likely you will need a serious transmission repair in the possibly near future.
Cheers,
Don
You definitely need to check the fluid level, and check for signs of fluid leakage. I'll attach one of the Jaguar documents that describes the procedure. As RJ recommended, you really should plan on dropping the oil pan and changing the filter, and it might be prudent to also install the Transgo revised pressure regulator valve kit, since the pressure regulator is a known issue on the ZF 5HP24 transmission that can lead to A-drum failure.
ZF LifeGuard 5
ESSO LT 71141
Pentosin ATF 1
Ravenol ATF 4/5 HP
Cheers,
Don
ZF LifeGuard 5
ESSO LT 71141
Pentosin ATF 1
Ravenol ATF 4/5 HP
Cheers,
Don
WhiskyTangoFoxtrot
06-16-2011 08:48 AM
