trans range selector prob
I've got error code P0705 w/ gearbox fault and restricted performance. I'm sure it's because the selector is way out of alignment. I get all the right side of the J-gate PRND but have to really move it around a lot to get to the left side. All happened because I had the console opened up and was moving the shifter out of the way of the audio unit. I inadvertently moved the shifter around and disengaged it from the plastic slider on the right side.
Now I think it doesn't know what gear it's in and mechanically the linkage doesn't line up. Is the a procedure for adjustment/alignment of the shifter?
thanks
thanks
Thanks. The "slider" I mean is a white plastic piece to the right of the shifter. A short arm with a ball end near the bottom of the shifter engages it so that it moves along a rod as you shift gears. I think it may be attached to the shift selector sensor, a black box to the right.
Without the J-gate top plate it was possible to move the shifter left and right besides front and back. That's how I messed up; the shifter became disengaged from the "slider" and I was moving the shfter around. I must have thrown something out of synch.
Hi
Look at this other forum thread - Stuck in park (etc):
https://www.jaguarforums.com/forum/x...-errors-61137/
It has a parts diagram and list of the parts in post# 15 and # 17.
Also read this forum thread:
https://www.jaguarforums.com/forum/x...d-issue-45238/
Look at post# 2 - about broken gearshifter parts.
Jim Lombardi
Jim Lombardi
