Transmission adjustment
I have been doing some research on transmissions for my 98 xj8. I am looking to adjust how smooth it shifts. It's not really bad, but I am reading that it is the same transmission for the e38 bmw's. I have had a few of those and the only way you can tell they are shifting is by looking at the tach.
I drove several jags and this one shifted the best by far. It was the only one I felt was acceptable...but if it could shift like my old bimmer, that would be top notch!
Is there any way to adjust shift quality in the 98 trans?
I found one related to harsh shifting (below) but I think I remember one that applied to the '98 -'99 cars that called for a reflash of the TCM. I have the entire TSB if anyone wants it or it is posted on the Xk8/R forum here:
https://www.jaguarforums.com/forum/s...ad.php?t=25334
You might try AllData. They have a TSB index that gives a one sentence description but not enough to totally understand the issue/solution.
I had a VERY harsh down shifting issue with an '00 XK8 but it up shifted perfectly. The torque converter did not release from lockup when a down shift was called for. The problem was the TCM and replacing it fixed the problem.
TSM 307-14
DATE 08/03
V8 XJ Series/XK
MODEL
2000-02 MY XK Range
2000-03 MY V8 XJ Series
VIN
A00083-A30644
F00103-F59525
Shift Quality Issues/Harsh Engagement With Engine Cold- ZF 5HP26 - Install New Transmission Control Module
TSM 307-14
DATE 08/03
V8 XJ Series/XK
MODEL
2000-02 MY XK Range
VIN
A00083-A30644
F00103-F59525
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-21-2015 08:07 PM
ahunt4
09-19-2015 06:46 AM
