Transmission chirp XJ8L 2005
Looking for advice on an issue I have recently noticed. Between 2nd and 3rd I am beginning to hear a small chirp sound and it seems to be getting more frequent. Very concerned about this. Also the car doesn't always seem to always downshift to 1st when coming to a stop. In other words, as I apply throttle from a stop, the car will begin to move in 2nd and downshift to 1st after a few feet of movement. This all points to transmission issues to me, but I'm a rookie
Your sage advice is greatly appreciated.
Thank you!
Marc
Thank you!
Marc
Received 2,263 Likes
2005xjx350 (08-18-2023)
You will get many more replies if you post in the correct forum. This is the X308 forum, you need the X350 forum.
https://www.jaguarforums.com/forum/x...-x350-x358-28/
The ZF6HP26 is for the later cars as the X308 uses a ZF5HP24 or Mercedes gearbox for the SC 4.0 version.
Plenty of info and TSBs from Jaguar about the SQUAWK while shifting.
Good luck.
bob
Good luck.
bob
