Is this the transmission drain?
I'll have a closer look at that next chance I get, probably not until this weekend.
Is that whats shown in this video at the 34sec mark? https://www.youtube.com/watch?v=NVbcuKcnC2Q.
The connector (picture above) -- is just that. It's where the harness from the car connects to the transmission. They can leak -- obviously not good. The leaking fluid can cause electrical issues .. so any fluid wetness around the outside of the transmission needs to be looked into. As above -- don't touch if not leaking. If leaking -- clean outside well -- replace and check fluid.
The conductor plate is inside the transmission -- the connector pictured above plugs into that part. The plate hols all the electrical connections inside the transmission. Typically with no leaks / low miles / intermittent strangeness ... the conductor plate gets replaced. You do the connector as well -- new filter/ fluid and pan gasket
Both of my R's have the original fluid -- no leaks .. tube never opened.
The video sows the procedure of removal and replacement of the internal "Conductor Plate", in the case a fault in it (its sensors) is diagnosed. You don't need to do any of that for the time being (unless a fault in your Conductor Plate is positively established) - just inspect the area around the connector for any signs of oil leak. If you have an oil leak, you still do not need to remove the sump - just get a new connector (genuine MB) and replace it from outside
But I think I still want to do the fluid flush and filter chance, I'm not a fan of lifetime fluids and filters, I just don't see them as a good idea and I'd rather have a serviceable part and a regular change interval.
Fault messages on the instrument cluster or error codes found when doing an OBD scan.
You may consider buying a complete transmission kit (https://www.ebay.com/itm/Mercedes-Tr...4AAOSw-W5UvXXS) or (https://www.ebay.com/itm/Mercedes-Tr...cAAOSwmrlUvWgr) as the Conductor Plate, sooner or later, will fail so it is good to keep a spare one. These are genuine MB parts. Beware of the much cheaper Chinese knock-offs.
My problem with that listing -- they are calling it Genuine MB. Maybe it's an OEM imported part -- in the USA it would be in a MB box. I would want a bit more info from the seller -- especially at his price.
To the OP .. check to make sure you don't have battery or other low volt conditions. If so .... fix that first. If you find that's your problem -- you have fixed the car. I would inspect the transmission again. The connector should be dry dirt -- if not you need to verify why it's wet.
Doing a proper service is not going to hurt anything -- but many times people don't preform it correctly. The lack of a dipstick etc. Also -- the original fluid is NLA from MB .... superseded / new number
The dog has a good point, you'll need to get one of those Merc tranny dipsticks as well if you plan on tackling this. It's the only way you can be sure you've got the fluid level right after (or before) you do what ever work you decide to do.
They're pretty easy to find on ebay as well, search on the 722.6 trans.
The one I found works well but I was surprised to find out that you just push it in until it stops (when the lower end hits a restriction). I'm used to dipsticks that stop against a feature at the top.
#28
Even with the "dipstick" it's still a process to assure correct level. Had trouble with my W210 wagon. Making sure it's bottomed out -- correct temps etc.
Lots of these transmission were damaged by good intentions .... it was one of the reason they made it difficult for casual maintenance.
The dipstick is inserted until it hits the bottom of the sump. You can then put a mark on it which corresponds to top edge of the dipstick tube. Otherwise, it has two marks for the fluid level - one if measured at 25C fluid temp and another one if measured at 80C fluid temp (interpolate for temps between 25C and 80C). The two marks are spaced at 45 mm so knowing the fluid temp at the time of level check is quite important. I normally do it immediately after starting a cold engine, taking the ambient temperature and adding some 5C to allow for some fluid warm up during the level check.
#31
Thanks I'll compare that to the dipstick i've got. Min looks different to that one, so I don't think its MB OEM.
jimlombardi
08-05-2011 12:23 AM
jimlombardi
04-16-2011 09:43 AM
