Transmission drain plug?
Finally found a shop (local garage) willing to put in a Transgo pressure valve update into the valve body.
So, presented for your consideration...
Looking at Trans filter kit, notice it has a replacement drain plug. Have not seen any mention of a drain plug on our Jag 5hp24 trannys, so thinking maybe the BMW 5hp24's have a drain port. Pending suitable research, might it be an idea to put on a BMW pan? Seems like it would make future changes of the "lifetime" fluid more pleasureable. Thinking shorter term fluid drains to dilute out residual converter remains.
vsol
04-15-2016 07:11 AM
