Transmission filter and oil change
Old 10-21-2009 | 10:41 PM
blish2u's Avatar
Default Transmission filter and oil change
2001 xj8 seems like all service has been done to car; no probs shifting etc (115k).
so whats the deal with the tranny fluid? ive been told it is NOT replaceable its lifetime for the zx trans. i think its BS and want to get a new filter and synthetic fluid in there asap
give me your comments please!
Old 10-22-2009 | 12:52 PM
ken@britishparts.com's Avatar
Just do a topic search. Loads of posts about this one.
Old 10-23-2009 | 12:51 AM
Dan R's Avatar
Any Mercon V synthetic will fit the bill. The filter is readily available.
Check the level with the fill plug off and engine running, tricky but doable.
Old 10-23-2009 | 11:42 AM
AlexD's Avatar
I would be sure to use a fluid that conforms to the spec, Mobil synthetic ATF is reasonably priced and specifically conforms to the ESSO spec, which makes sense since Mobil and Esso are the same company. You can find the Mobil fluid almost anywhere.
Old 10-28-2009 | 12:43 AM
blish2u's Avatar
thx peeps!
ZJag
26
09-05-2016 03:33 PM
bdboyle
09-04-2015 06:16 AM
Jag-o-nomic
09-04-2015 03:07 AM
pnwrs2000
09-03-2015 11:55 AM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: Transmission filter and oil change
