Transmission issue
UPDATE- After removing the trans again we found the problem. Man do I feel dumb. After removing the old A drum I didn't realixe there was a couple spring like plates and a psiton(I guess that's what it's called) that had to be transferred to the new A drum.
After removing we did an air pressure test through the pump housing. After reassembling CORRECTLY we tried the air test again and clutches and olates all moved. Reinstalled trans and glory be she moved in first. Took it out for a spin and dove great. Going to put about 30 miles on it today will then check fluid again tomorrow.
Although we got 2.6 gallons in it. Thanks to everyone for ALL the help.
